halhawkins's avatar
halhawkins
MPPT/DC to DC Charger for Trailer Build
Hello all, first time poster.
I am currently doing a special purpose conversion of my enclosed gooseneck and am at the point to figure out electricity. I have a lot of 12V equipment, especially strip lighting that takes up more amps than shore power (coming from the generator) can provide. The 120v equipment/AC will use about 24a. The 12v equipment will use about 90a and each job for the trailer will be about 2 hours so a total of 180a will be used, so my idea was to use two deep cycle batteries as the main source of power with the batteries being charged while driving/hooked up to truck or when connected to shore power.
I thought a DC to DC charger like the Renogy DCC50S 12V 50A DC On-Board Input MPPT Charger would work but Renogy told me that using shore power with an AC to DC converter would not work with the device in lieu of solar power. So I am trying to find a device that would charge the batteries from 2 different sources. Its very unlikely that the 2 power sources would be used simultaneously to charge batteries (but possible?). I've put a rough draft schematic below to give you all an idea. Would love to hear your thoughts. Thanks very much in advance.
