Itinerant1
Apr 16, 2022Explorer
BFL13 wrote:
Are those operating from zero to full SOC not hitting LVD at "zero" ? Why not? It is all very strange. What is "zero" is the mystery in that case.
PT- seems LFP rating is done different ways then. I saw where it was done at 1C. The 20 hr rating was then stated as the same given no Peukert
FLAs have various rating by convention for type of battery. Starting vs Golf cart etc. AH and RC. No news there.
LFP capacity is confusing especially when they use watt hours and what is remaining capacity wrt SOC vs using AH and remaining capacity. We did all that in past threads. That engineer's speech that was linked on here explained how they sort of fudged where half way down is between watt hrs and amp hours.
The OP in this thread does have a clue and a monitor, so he might or might not be interested in this other stuff.
What are you calling zero? SOC zero% = what ever the bms is set for whether 2.8vpc or 11.2v battery pack? If you mean zero voltage... well good chance it's a cooked battery.
