opnspaces
Jul 09, 2020Navigator II
At least it's stuck open and not closed. Really your choice is to replace the valve. Put your truck in a steep driveway or up on ramps in whatever direction for 5-10 minutes to allow more complete drainage of the tank. Then you can level it and pull the camper if necessary and change the valve.
Typically you have to loosen or disassemble the drain pipe enough so be able to slide the valve out. After that it's 4 bolts out and in and then you're done.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
