greenrvgreen
Sep 15, 2014Explorer
Thanks for the link, MEX. A few things pop out at me vs my UPG batts:
--Charging voltage is somewhat lower. Lifeline says 14.4 at 77f vs a range of 14.5-14.9 for the UPG. Is there a correlation?
--Lifeline says go ahead and shove 500a at their 100ah batt. Does this mean I can use my 45a IOTA DLS45 with my 100ah UPG's (if I have the shore power)?
--Their second stage (where voltage is equalized and amps naturally taper) takes it down nearly to zero. This means with a 13a Meanwell all I have to do is watch the AC comsumption drop, then I can take over with teh 4a multistage charger.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
