joshuajim's avatar
joshuajim
Mar 20, 2021
My Dometic 15K has brain fade
Getting ready for the first trip of the year in a couple of weeks. Fired up the AC to check it out. Stat is single zone. Set the temperature and let it run for a while. Won’t shut off at the set point. It kept running until it was 10 degrees below set point and I shut it down.
I re-initialized stat but no change.
Any ideas?
  • wa8yxm wrote:
    1: Does stat run both AC and Furnace? And 2:is it "electronic".
    if it is electronic then it needs power.. Normally most Heat/Cool stats get poer from the "heat" side (Furnace) and run on a rechargeable battery during Heating cycles ... That battery may need replacement.
    Some use replicable batteries. and again replacement may be needed.
    I do not know about yours
    Mine Factory the A/C itself (one of 'em) operated the furnace and drew house power.. When that A/C went bad I the new one did not have the ability to control the furnace. So we taped off those leads and I put a mechanical T-Stat on the wall. It did not need batteries.. and since it was "Mercury Free" it did not even need to be level.
    Per my post, the stat is a Dometic single zone which is totally electronic. It runs both AC and Furnace and is working with both, but on the AC side it will not turn off once activated. No batteries in this system. Runs off house 12v. Thanks.
  • wa8yxm's avatar
    wa8yxm
  • What I have observed on my RV is the temperature may be at the set point on a thermometer sitting on a counter top but different at the single zone thermostat. From what I can see the thermostat is picking up the heat soak from behind the cabinet. It reads 89 degrees when at the countertop and most of the RV is at the set point. It never matches up until the sun goes down.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
