Weldon's avatar
Weldon
My Magnetek converter
My converter is 16 years old, it has 2, 30 amp fuses for 12 volt operation. If you only have 1, 30 amp fuse rather than 2 what is the result?
This occured and was this way for a week. Went out to open the slide and it opened fine- operates off the 12 volt system. As we turned lights on, what would be 12 volt, they became dimmer. After setting overnight the battery would build some power but diminish quickly. Battery showed 10.9 volts. All 120 volt items work well.
Volt meter on 2 large wires in front of converter showed 9.9.
Is battery bad and converter?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
