SNOPRO711X's avatar
SNOPRO711X
My water pump quit
I am currently on a trip and my coach water pump quit. The coach is a 2003 Itasca Horizon. The pump does run but does not draw water from the tank. I did run a hose from the pump intake to a bucket of water and the pump will draw water from the bucket.
I am wondering if I have a problem with the electric bypass valve. After I took things apart I found two of these valves. I am nor sure exactly what they do. The solenoid on the one in the back was hot.
The other strange thing was that when the water quit it was right after I started the generator
Any ideas?
Thanks
  • empty tank? its sucking air from the tank to the pump . mine has a filter housing that cracked ,.
  • Now that I have made it home, can anybody tell me if I can just leave this valve bypassed? Also any idea why I had power to the valve all the time?
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
