JJM5017
Oct 09, 2014Explorer
Nash 26J Electrical Issue
Hello all. I'm venturing into the RVing world and am hoping to get some of your expertise with an electrical problem I have run into.
A little back ground. I purchased a 2002 Nash (Northwood) 26' tow behind that has been sitting for a while. It's in great shape but I bought it without the ability to check the utilities (which I knew going into the sale). Anyway upon getting it back to my house I discovered there are some electrical problems which are getting rather difficult to trace. Here is the turn of events.
The battery was stone dead when I got it and after trying to revive it I finally gave up and purchased a new one. In the meantime I attempted to plug the 30amp RV plug into a 20amp household outlet (to run some tests before using a 30amp generator) and the trailer immediately kicked the GFCI. Regardless of whether my breakers were all of or any on as well as regardless of whether the ac/dc converter was plugged into the trailer 110v outlet. After doing some research on here I assumed it was either a ground fault or a just a bad idea to plug into a household outlet (by household I mean a fairly new pole barn in which everything is GFCI'd). Next I pulled the breaker/fuse box, checked all of the wiring including the shore power cord and found no issues. When I plug the ac/dc converter into a 110 extension cord from the pole barn I get all of my 12volt items (refrigerator, lights, stereo, heater, etc). When I unplug the ac/dc converter and run off my new fully charged deep cycle battery I am getting nothing (but there is a rather large draw on the battery as it dropped from 12.8 volts to 12.5 with all known devices turned off in the matter of 30 seconds). I have since run a dedicated 30 amp RV outlet but am still having the same issues as before.
Essentially I have good 12 volt power when the ac/dc converter is plugged in directly but otherwise have no power in the trailer (from battery or from 110v). I began tracing all of the 12 volt and may have found a few contributing factors (bad connections) but nothing that has made a difference. My next step is to pull all of the 110 volt outlets and check for a neutral/ground issue. Is there something I could be overlooking since I'm getting nothing from the battery or RV shore line? If my ac/dc converter (I say converter because I'm still not sure it also inverts or if it only charges the battery) was bad that still wouldn't explain why I am having the shore line power issues, correct? I'm in this for the long haul so if there are any suggestions on what I should check next I am all ears. I have a fairly decent understanding of electrical systems but have no past experiences with campers and am fairly handy so I am willing to try it all.
Thanks in advance for your potential help!
