time2roll
Oct 12, 2021Nomad
profdant139 wrote:Panel is probably 18 to 22 volts and is cut to 14.x at the controller.
Very interesting points about moving the controller -- I will have to experiment with that to see how much difference it makes.
If the 18 volts drops to 15 through the wire to the controller it may not matter much as the controller will still put 14.x on the battery.
If the controller is at the panel you have 14.x going through the long wire and limiting power to the battery.
