path1
May 05, 2016Explorer
Need help on part name so I can order
The manufacture on my A/C way over tightened the four mounting bolts at each corner. By "over tightened", I mean they wrenched it so tight that the metal bar is bent up on all corners. Last year I just made sure bolts were still tight on A/C gasket. Starting my annual inspect and noticed one bolt came through. Only 3 bolts holding A/C right now. I want to replace the metal part the A/C sits into the vent hole.
What is the part called?
Mac 3
Mac 3
