crcr
Oct 01, 2020Explorer
Need Help Understanding AC Vent Cover!
I was tightening screws and reattaching my main TT AC vent cover, and have some questions. Besides this large main vent, this unit does have five small round vents throughout the 28 ft TT
Below is an image of the inside of the vent cover. The top black section (a thin washable filter) covers the cold AC supply to the room.
The bottom section of the vent cover, covers the return air portion of the unit in the ceiling. However, as you can see in the pic, there is a piece of galvanized sheet metal covering that area, plus a rubber gasket under that sheet metal, the same size as the sheet metal. I am the second owner of this TT, but the piece of sheet metal and the rubber underneath it, very much seem to be factory and not something that the first owner added.
Without the cover on, both the air supply and the air return move a pretty good volume of air. With the vent cover on, due to the configuration of the vent cover, I don't get near as much air movement as without the cover on.
Questions:
Why does that galvanized tin plus full size rubber gasket cover the return side? What is the purpose of it?
In the pic you can see the slot vents along the perimeter of the vent cover. It would appear that they are for the return air, since they surround that side. Is that correct? And should they be open or closed? Opening them seems to perhaps increase the air flow a little bit.
