time2roll
Sep 05, 2014Nomad
Are you planning to replace the 120vac/12vdc power center to be 50 amp rated?
http://www.bestconverter.com/PD4560-50-Amp-Power-Center-60-Amp-ConverterCharger
If you connect the generator to a NEMA 14-50 outlet you can just plug the main cord into the generator as needed. You are the manual transfer switch. Many motorhomes have this set up. Lowest cost.
