Winged_One's avatar
Winged_One
Need help with removing taillights.
2011 Coachmen Brookstone
How do I access the bulbs and wiring on these taillights? (see pic)
Do they pop out toward you?
Accessing from underneath/behind looks impossible as it is completely sealed by being boxed in and sealed shut by the trailer.
They are Wesbar lights. They are NOT LED lights.
  • I just push mine in on one side. They will swivel inward and you can the pull out the rubber and the light. Mine were sealed units with no replaceable bulbs. I replaced all four with LED lights from Harbor Freight. Very happy with them. Cheap price too.
    B.O.
  • To put them back, spray with soap and water, makes them slip back in place
  • wa8yxm's avatar
    wa8yxm
    On mine I press anywhere along the edge, they "pivot" usually 90 degrees from where I push, then I pull them out.. Getting them back in takes a bit of observation and control.
    Mine were not LED. are now.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
