- AlmotExplorer IIIdouble post
- AlmotExplorer IIINo way I would say to just get 150W panel for solar-only living, with fridge, TV and CPAP.
For fridge and lights alone, - yes.
Or as an auxiliary source, like battery maintainer in addition to generator.
150W will harvest 25 AH in Ca or Az winter, - on a good day. - DesertMaxExplorerThanks again for the avalanche of great solar information..
When I went full time in 2013 I had compiled half a notebook of notes and technical data. Much of it is coming back now with your help and things do not appear to have changed all that much..
At this point a couple of notes come to mind: I think it was Almot who said to just get a 150W panel...
and NinerBiker mentioned that he had a 150 and I think he said he got it for about $35.00?
Well this maybe the point of change I had anticipated because it may be true that every couple of years or so, prices on main components may have actually come down.. For instance HERE at Ebay they have a 150 mono panel for just 200 bucks.. - DesertMaxExplorerbrulaz, I remember those.. very budget minded yet highly effective piece of equipment.. thanks for that..
- AlmotExplorer III20A PWM in the Niner link, $40.
AH meter, another $40.
Invest the rest in one more 150W panel.
Your batteries will thank you. - DesertMaxExplorerThanks..
- AlmotExplorer IIILooks like happy hour is in full swing already :)
30A combo by Tri for $250-300 for a 150W panel?
20A Rogue MPPT - nice controller, I have their 30A version, but there is no need for MPPT here.
150W is fine with 10A controller.
Battery monitor is optional. You can get $40 meter on Amazon to measure AH if you think you need it.
If you need both controller and monitor, and plan on 400-500W array, and OK using PWM with array of that size (which is not a very common setup) - then getting a Tri combo makes sense. Tri controller is matched to their monitor, yes. It's an add-on, can't perform well on its own.
High-end standalone controllers can function on their own, though those are MPPT - you don't need those either. - DesertMaxExplorerThanks so much for all the great responses..
smkettner, wow.. I had forgotten so much of what I learned back in 2013 & 14! Trimetric.. Of course! They match up their units like nobody else.. I had studied old Solar Bob, Crazy Bob.. can't remember his handle but everyone seems to know of him..
I also learned about how the cardboard wall mounted factory issued meters measure the voltage as it is in the wire "at that point" and not a true measurement at the battery so all high end componentry is really important. I'm getting Trimetric Controller and Batt Mon!
Great stuff.. I was once a Licensed Contractor and an Engineer and often worked both fields at the same time.. Now I have Complex Sleep Apnea and I think I'm getting reverse training.. Sad! - NinerBikesExplorer20 amp adjustable voltage charge controller.
I run this with my 150W 12V 8.9 Amp poly solar panel. This is the unit I bought, but in the 20 amp model, for $35.99
my unit
I like that it will tell you the voltage at the battery terminal, versus the voltage set point.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
