BFL13's avatar
BFL13
Nov 27, 2018
Neutral to Frame vs Floating Neutral Question
Been discussed here a few times, but can't remember the difference if any.
Onan here has neutral bonded to frame and it is for RV use.
https://www.usedvictoria.com/ReportSelectUsedAdPhoto2?used_ad_id=32655856&position=3&hb=1
Typical portable gens have floating neutral and we don't use their chassis grounds. With that Onan are you supposed to link the chassis ground to the RV frame?
In a motorhome set-up, how is that done? (that one in the ad came from the guy's 5er apparently )
