Boxer_Lovers's avatar
Boxer_Lovers
New Dometic Heat Pump Stinks
Sitting here this morning, 48 degrees outside, so I flip on the Dometic Heat Pump. One hour later the inside temperature has risen ONE DEGREE!
I've had heat pumps before that would run you out of there in about ten minutes and you'd have to shut it down. With this new energy saving unit I have to run the furnace and heat pump to get any heat. I paid the dealer to have the h.p. installed when I bought the rig knowing I woild be staying in cool climates. Really efficient.
New isn't always better.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
