MELM's avatar
MELM
New Dometic Recall Initiated March 11, 2008
Thanks to the members who have provided info on this new one.
Dometic has a new recall for refrigerators made between June 1, 2003 through September 30, 2006. Many of these are the same models as were in the older recall (Recall number 06E076000). (Technically, Dometic’s letter indicates an extension of the original, but NHTSA assigned a new Recall Number and the information is under that new number.)
Since it has a new NHTSA number, I’m starting a new thread on this one; but the actual work appears to be the same as in the first recall.
Text from the NHTSA website Recall 08E03200.
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
Recall Number: 08E032000
Summary:
DOMETIC HAS REPORTED A SAFETY RELATED DEFECT COVERING 745,574 TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN JUNE 1, 2003 AND SEPTEMBER 30, 2006, WITH SERIAL NOS. 320XXXXX THROUGH 352XXXXX; 401XXXXX THROUGH 452XXXXX; 501XXXXX THROUGH 552XXXXX; AND 601XXXXX THROUGH 639XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS REPLACEMENT EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL/MAY 2008. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Some more links:
Dometic Recall Site
Dometic letter of April 11, 2008
NHTSA Response letter of April 21, 2008.
And here is a link to the original recall thread: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
Edited to add a link to the original thread.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
