Munk888's avatar
Munk888
New House Batteries, Converter Beeping?
Hi. Lot's of learning going on! We have a 2003 Fleetwood Tioga and we killed the batteries during storage. Didn't disconnect them and that damned LP detector wiped the batteries out: chassis and house, so we think... So we got a new chassis battery first. Replaced that ez pz. Went to replace the house batteries and that is when the proverbial poo hit the fan. We had 2 Napa deep cycle batteries at 75amps each. I hit autozone and got 2 Duralast 65amps batteries. Swapped em out. So far so good. Kept the wiring the same. Now, when we turn the rig on, there is a shril continuous tone coming from the converter (the plug with all the wires and fuses?) area of the battery compartment. Lights don't turn on. Generator won't kick up. Are converters amp specific? IE, should I swap out the 65amp batteries with 75amp batteries and keep all the things like for like? Any helps appreciated!
imgur pictures
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
