- donfrumpExplorer
DSDP Don wrote:
Is this a Monaco coach?
don
hes figured out the problem it was not a jack buzzer he was hearing
as it turns out - DSDP_DonExplorerIs this a Monaco coach?
- Amberlynn072ExplorerThanks again donfrump
- donfrumpExplorer
Amberlynn072 wrote:
After 5 months, the problem has been solved. It was the parking brake buzzer. Thank you guys for all your help.
well that's pretty close to a jacks down buzzer LOL - Amberlynn072ExplorerAfter 5 months, the problem has been solved. It was the parking brake buzzer. Thank you guys for all your help.
- wolfe10Explorer
Amberlynn072 wrote:
HMH jacks
Do you mean HWH jacks?
If so, correct stow procedure is to start the engine, hit "stow" AND MOST IMPORTANT-- DO NOTHING ELSE.
It will continue to bleed fluid back to the reservoir for a couple of minutes. If turned off by you, it can trap fluid in the lines.
And, check the fluid level (dip stick on the reservoir) with jacks stowed (but that is not the source of your alarm). - Amberlynn072ExplorerOnce parking break is released, within seconds it starts beeping.
- donfrumpExplorer
Amberlynn072 wrote:
HMH jacks
you mean HWH do like I suggested run jacks part out and back and see if that fixes it if not u may have one jack not closing 100% or sensor at jack bad or out of ajustment - Amberlynn072ExplorerHMH jacks
- SprigExplorer
fishingbob61 wrote:
In the picture of the pump is a sensor with 2 red wires, unplug the wires and if the beeping goes away...
That may not work... are you certain?
I remember trying this when my own system was being stubborn and it turned out to be opposite of what I expected.
Well, it might work, I simply don't remember.
