wolfe10
Dec 26, 2015Explorer
Amberlynn072 wrote:
HMH jacks
Do you mean HWH jacks?
If so, correct stow procedure is to start the engine, hit "stow" AND MOST IMPORTANT-- DO NOTHING ELSE.
It will continue to bleed fluid back to the reservoir for a couple of minutes. If turned off by you, it can trap fluid in the lines.
And, check the fluid level (dip stick on the reservoir) with jacks stowed (but that is not the source of your alarm).
