โNov-29-2018 10:01 AM
โDec-15-2018 11:03 AM
โDec-15-2018 08:07 AM
โDec-15-2018 07:36 AM
2112 wrote:
My Megawatt S-350-12 goes into constant current mode (CC) at about 32A and the voltage folds back accordingly. No hiccup. I've operated it in this mode for maybe 10 minutes at the most so I do not know how it would hold up long term. I can't speak for the other models
โDec-15-2018 07:32 AM
โDec-15-2018 06:13 AM
โDec-15-2018 04:47 AM
โDec-15-2018 04:38 AM
DieselBurps wrote:If you are referring to
I have the first voltage amp meter that is linked, purchased from amazon. Can anyone tell me where to hook up the yellow wire? I know red + and black - go to their respective spots on the megawatt but am unclear what to do with the Yellow wire?
โDec-15-2018 02:22 AM
I have the S-350-12. They have 3 terminals per side. I used 6, 3' 10AWG stranded. I crimped 12/10awg fork terminals on each wire for the power supply end and bundled the 3 and crimped a 8awg eyelet on the battery end. Make sure the terminals for the power supply end will fit the power supply terminal strip.
To measure current I bought This. If you don't have a voltmeter you may be better off with This
I adjust my power supply output to 14.5V before I connect it to the battery to allow for line loss. When it gets down to 1A my battery voltage will be ~14.4V.
A timer is a good idea, set it and forget it
โDec-03-2018 12:28 PM
โDec-02-2018 08:26 PM
MEXICOWANDERER wrote:
Worst case scenario manipulation. Virtually worthless
โNov-30-2018 06:58 PM
โNov-30-2018 01:27 PM
โNov-30-2018 12:19 PM
โNov-30-2018 11:05 AM
โNov-30-2018 10:26 AM
