  • The very first mod I do to a camper is to wire all electronic stuff to the batteries. The refrigerator, the furnace, LED lights, everything. Use you converter as a charger only. But this is coming from a guy who the last time I used shore power was in 1988 at fort wilderness FL. And yes that camper, too was all battery with the converter acting as a charger, when it was plugged in. DO NOT EVER TRUST A CONVERTER TO SUPPLY CLEAN RELIABLE 12 VOLTS!!!!!!!
    SRD 357
  • NinerBikes wrote:
    Here's what I am using, so far, so good, happy with them.
    48 smd light panels.
    Color is about 3000-3300k in temp, and they are easy on batteries if you are boondocking, maybe 4 to 5 watts per panel, versus 18 for the 921 bulbs they are replacing. Low in heat generation too...
    I have used the same now for two seasons, work great, no duds yet. :)
    .1 amps each I think. VS stock 1amp bulbs.
  • Here's what I am using, so far, so good, happy with them.
  • LED light solutions thread pros and cons
    Shadow Catcher wrote:
    This brings up the voltage tolerance of nominally 12V LED arrays. All of our lights are LED and they are, 'China not particularly expensive' and I carry spares. So far none have quit/burned out.
    It would appear that it depends and possibly luck of the draw as to what you bought.
    See http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24525418/gotomsg/25305424.cfm#25305424
  • This brings up the voltage tolerance of nominally 12V LED arrays. All of our lights are LED and they are, 'China not particularly expensive' and I carry spares. So far none have quit/burned out.
  • I wish converters would regulate their output to the rig while charging. Either would eliminate the need for expensive regulated LEDs.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
