MEXICOWANDERER
Oct 29, 2018Explorer
Nifty MOSFET Complete Rectifier 10 amp
![](http://www.mpja.com/images/35486.jpg)
Small module designed as a "Ideal Diode" with a very low Vf (Forward Drop). Features 2 D403 very low resistance P-Channel MOS transistors with associated components.
Used to prevent reverse current in Solar Systems, Chargers, Parallel Battery systems.
Input: 4-28VDC
Current: 10A Rated 15A (max.) Surge: 18A
Additional Heatsinking recommended at >10A
Operating Current: .7mA @ 12VDC
Operating Temperature: - 40 ~ + 85 C
Connection: Solder Terminals
Typical Forward Drop:
Load 2A: voltage drop 0.0086 V
Load 5A: voltage drop 0.022 V
Load 8A: voltage drop 0.036 V
Load 10A: voltage drop 0.042 V
Load 12A: voltage drop 0.052 V
Load 15A: voltage drop 0.075 V
L: 22mm W: 20mm T: 8mm WT: .01
Stock No: 35486 DI
Be the first to review this item
$4.95
http://www.mpja.com/10-29-18.asp?r=386312&s=5
