MrWizard's avatar
MrWizard
Moderator
Mar 15, 2022
No hot water flow, stopped up ?
Atwood G6A-8E, RV 1997 Fleetwood Bounder 36S
The WH is in a sealed box next.to water bay, this is outside under the RV, no access to connections.at back of WH,
Water goes into the water heater , it does not flow out the taps, I.removed the drain plug and only clear clean water comes out, no sediment, leave drain open turn on water pump.lots of Clean clear water comes out,
When I turn Bypass valve to bypass mode, hot water taps have cold water good flow,
I.have tried compressed air into the hot water drain in an effort to clear any clog and flush the water heater afterwards, it did not work, I have done this to both HW and CW drains and lines taps closed water heater drain open, I'm.ready to buy a borescope to examine inside the wh to look at the HW outlet, also going to remove and look at the bypass valve, some pix.to explain
Last photo underneath RV looking up at the sealed box, metal covered with vehicle undercoat, the two flexible LP lines are visible, they goto WH & the rear furnace
I hope our resident experts can shed some light on fixing this, I'm hoping for.flex lines inside the box, so I can slide the water heater out, maybe it's a clogged check valve of some kind
Sorry about the photo size, I'm on my phone, not as easy to manipulate pages and photos
