MrWizard
Mar 29, 2022Moderator
Yes there was some calcium deposit, I cleaned out of the elbow, there could be some in the WH but all I ever get when flushing or draining is clear water, any deposits are harden and pre-existing from the previous owner, I was surprised when I saw the deposits in the elbow and check valve,
I thought about removing the pop off valve and pouring a few gallons of CLR into the water heater via a funnel and letting it soak overnight, put it on bypass leave it turned off,
Then drain & flush the next day
Any body try this,
I've been looking at Cellphone Borescopes online , it's been several times now that I could have used one to inspect a problem situation
Any body try this,
