Ivylog
Sep 08, 2015Explorer III
The rubber mat burned the coil up and it's blowing the protection fuse. Here is a $58 replacement and says it's a latching relay... only requires a short pulse of power to activate. Connect the two big cables either side together and you will be fine until you can replace it.
