Old-Biscuit
Aug 18, 2015Explorer III
cekkk wrote:Old-Biscuit wrote:
30A fuses you pulled.......where they on the 'converter'?
IF so....those are 'reverse polarity' fuses that would trip/isolating battery if it was hooked up backwards (also w/o them no recharging from converter when on AC Power)
Auto resets...20A probably for slide out and 12.5 probably for power jack
Those two 30 amp fuses are at the top of the panel where the breakers and 12V fuses are located. That's the best I can say.
Most likely 'reverse polarity'
