wxphoo2
Jun 11, 2017Explorer
No power to leveling jacks
I have a 1994 Vogue Prima Vista diesel pusher, with the HWH 100 series leveling jacks. The control panel is separate from the levers.
For some reason, I do not have 12v power to the control panel, either with the key in ACC or ON. I applied 12v from a separate battery, and the control panel, pump and jacks worked fine. I put a volt meter on the 12v line coming in and got nothing. Chassis battery is fine, no other electrical issues with the coach. I have attempted to trace the 12v line as far back as I can, in an attempt to find a fuse or loose connection, but I haven't found anything to this point. I have also tried to find loose ground wires, but no luck there, either. The fuse in the chassis panel which includes the jacks is good.
What am I missing? Is there a fuse I haven't found? I have seen references to a "control box" in some posts. Does the 100 series have a control box in addition to the control panel or is this only on newer systems?
Thanks for any suggestions anyone might have. By the way, I do have a call in to HWH and am waiting for a call back.
