Boon_Docker
Mar 03, 2021Explorer III
dougrainer wrote:Boon Docker wrote:MT BOB wrote:
Really? What is an RM8,there is virtually no info on the net.And,seems you do not understand logic,when the thermostat calls for more cooling, the flame gets higher, and the increased flame makes the ammonia heater work harder, producing more potential to remove heat from the inside of the refrigerator.AND,as it appears you do nothave/own a fully electronic refrig. your symptoms are perfectly normal.same as if you do not take your foot off the gas pedal, when rushing downhill.
:h
So when the fridge is running on 120V instead of propane does the heating element receive more power to make it hotter.
It seems someone here does not understand how an absorption fridge controls the temperature in the N306. :)
BYPASS Refers have a BYPASS tstat that regulates the flame height. These refers have an additional mechanical 120 volt point Tstat. You do not understand how it controls.
This particular refer does NOT have a Bypass tstat. It has a mechanical GAS tstat. The instructions clearly state that it has LOW-MED-HI for Gas control. YOU have to manually go from the 3 settings to change the temp if it gets too cold. It does NOT change the flame height like a bypass gas control. Doug
I guess I am the one that does not understand the operation of the N306. :S
My apologies to MT BOB
