Sinnettc's avatar
Sinnettc
Norcold fridge won't light on Gas setting
Went through everything except the hot water heater in our new-to-us TT this weekend. Norcold fridge runs fine on 110 but I only managed to get it to fire off on gas once, and that was after going through the Off/Gas cycle 4 or 5 times. Today it wouldn't light a fire at all.
Is there anything adjustable behind the external access door/vent or am I going to have to run it over to the RV repair guys to beat it into submission?
  • Thanks for that link. I did search the forums for Norcold but apparently didn't get the right keywords.
  • You probably have a minor problem with the spark ignition. The ignighter might be shorted to ground, or the flame sensor is not working right.
    Try lighting it with a BBQ lighter. See if the flame stays on or not.
    If that fails, or it stays lit for a few seconds then goes off, you probably will need to take it someplace.
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
