Leo_Renaldo's avatar
Leo_Renaldo
Norcold mod 6162
You can have the temp slide all the way down to number one and it still freezes everything I have to turn it completely off 12 hours a day to avoid freezing milk or water... How could I repair this... norcold mod 6162
  • The thermistor is the temp sensor that the thermostat uses to control cooling cycles
    The thermistor plugs into the UPPER control/display board...runs over the top of fridge, down backside and then enters food compartment where it is attached to a fin with a small clip.
    The thermistor MUST be in contact with the FIN
    If not...it will cause over-cooling due to lack of temp sensing.
    If thermistor IS attached to FIN then it is no longer functioning and that causes over-cooling regardless of thermostat slider position.
    Thermistor part number (same thermistor for all 60/6000 Series)
    Norcold 61693822
    Unfortunately it is no longer available
    So best option is 'Snip-The-Tip' sensor replacement
    Snip-The-Tip Replacement
    600/6000 Series Manual
    PARTS
  • Verify that the thermistor cable is securely plugged into circuit board.
  • wnjj's avatar
    wnjj
    Most likely needs a new thermistor. When they fail they can cause full time cooling. It’s the little part that clips onto the fins in the fridge compartment. Under $20 on Amazon.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
