- 1492ModeratorMoved from Forum Technical Support
- Old-BiscuitExplorer IIIHere are 3 different reset procedures from Norcold for the 'no co' error code. Which procedure depends on which model & serial number
LINK
Read thru procedure before doing any reset. - ScottGNomadHappens when fridge has been run off level even though it may have been within Norcolds specs and probably for other reasons as well.
You need to reset the PCB.
1. Take off the cover of the circuit board
2. Reset the board by shorting to ground, Pin #11 for 3 seconds.
Cheers
Scott
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
