dougrainer
Aug 12, 2013Nomad
holdn2aces wrote:
Doug, this unit is in a Jayco 30JTX, the reefer is not in the slide portion. I have investicated more and was going to try the suggestion you proposed next weekend when I get back to my trailer. I do not have an amp meter to test how many amps the heater is drawing but will try to get one for next weekend to confirm if the heater is within spec. Do the control boards go on these often?
Amp meter is not needed. The Heat element either works or it does NOT. So, if it gets hot it is working. Control board failure is not that common. Doug
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
