motraveler's avatar
motraveler
Norcold refer venting
Hi - newbie here.
I had to rebuild a section of flooring and needed to dismantle the vent tubes from the refrigerator. Norcold 61X I think. The two large dryer type vent tubes are OK. One smaller one goes to the exhaust. I just need to know what to do with the other small one which I assume is intake? Does it need to be connected to something?
Thanks in advance,
John
  • Thanks for the manual! I'm thinking a picture will be worth a thousand words here. I'll see if I can upload one. It's at the bottom, underneath the refer box where these vent tubes are. I think it must be part of the propane burner device.
  • Make and model of your rig will help!
    Try putting in your signature or profile.
  • Are you sure these are for the fridge, and not just furnace ducts that happen to be run in the space underneath the fridge?
  • That is a possibility I never considered. They never made much sense as part of a refrigeration system anyway. I'll take a look at the manuals I have and see if they have any info. Thanks for the replies!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
