june19003's avatar
june19003
Norcold refrigerator code says "no co"
We have a Norcold frig. that says "no co". It is the 1200im model in a 2003 Monico Knight. Anyone got any ideas about what could be causing the problem. Really don't want to spend thousands of dollars on a new frig. if it is just something simple to fix. If I do have to buy a new one, where would be a good place to buy one in North Central Florida? Thanks in advance for any advice.
  • If it turns out the cooling unit has failed do yourself a favour and contact "www.rvcoolingunit.com". I had a new Amish cooling unit installed in my 1200 two years ago. I cools better than the original.
    Very cost effective.
    Bob
  • According to what I remember of the booklet, and my past experience, No Co code means the frig has turned off because it was out of level, out of power, out of propane. With my 1200 it gave ONE chance only to correct the situation. Make sure you are level, make sure batteries are at least 12.5v (not sure which batteries, with mine it was the engine battery) and check propane. Then you can try to restart frig. If you get the No Co code a second time a technician must reset the motherboard. This was done by pulling all the wires, shorting out the board with a paperclip, and reconnecting. In my case, all worked well for another year or so. Then, probably unrelated, I had a coolant leak and had to replace the coils. This worked well for another year, about $1200, and I traded in the MH for my new Allegro with residential frig.
    Good Luck.
  • Posted: 01/25/15 07:45pm Link | Quote | Edit | Print | Notify Moderator
