- IB853347201Nomad IIIs the fridge set on Auto? Check the owners manual?
FANC 1 wrote:
Check the back of refrigerator see if a red light is lit on the temp limit switch. If so you need a magnetic to reset the switch. Search youtube for more info. Mine was a Norcold 1200.
The recall switch shuts the complete operation of the refer down. NOT just certain parts. Doug- FANC_1ExplorerCheck the back of refrigerator see if a red light is lit on the temp limit switch. If so you need a magnetic to reset the switch. Search youtube for more info. Mine was a Norcold 1200.
- ScottiemomNomad III had that happen. The outlet the fridge plugged into in the back was one of those old ones that the parts were pressed into. Over the years, everything loosened up and it wasn't making constant contact. A friend of mine, an electrical engineer put a new outlet in it and it's been running every since.
Dale - CA_TravelerExplorer IIICheck that there is power at the 120V plug. Then check the fuses in the back.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
