TakingThe5th
Jan 19, 2014Explorer
I would suggest putting the battery back in and see if the situation improves. The battery does improve the quality according to my manual.
As you install the battery, take note where you left the loose battery cables - is it possible that the positive cable is near a ground source? If so I bet you have a really crappy 12 volt source. As was pointed out, all your control boards use 12 volt power.
I hope it's that simple for you. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
