Ok to run shore power without battery?
144Grayling
I have a 2007 Komfort trailer with a WFCO ultra distribution panel model WF8955an with a 3 stage converter. Lately the fan in the panel has started running for hours at a time. I checked the battery and it is boiling HOT. We donโ€™t travel, the trailer is plugged into shore power 100% of the time. Is there any problem with removing the battery and just having the 12v lights and bath fan run off the converter?
49 REPLIES 49
wa8yxm
StirCrazy wrote:
looks like your converter is fried. should be 13.6 to 13.7 with no battery hooked up. so, you likely need a new converter and a new battery
I'd need to haul some serious test gear into his rig to make an "Diagnosis" but.
13.6 volts DC is not the same as 13.6 RMS.
The old Magnetek 6300 Well if you read on the older analog volt meters the DC out was like 12-12.6 but if you read on the type of hardware I have you saw 18 volts (Depending on the device. I have both kinds)
so his 12 volts... might just be poor filtering of a supply with lots of ripple. Or it may be a very smart converter that says "Well I do not sense a battery so I'll go with the lower voltage"
Some I'm told do that. never seen one but that's not the business i'm in.
But if you are planning on running w/o battery by all means.
If it's a trailer you need to tow.. Use a battery tender on the disconnected battery. re-connect to tow
Or upgrade converter to a Progressive Dynamics 9200 series. (or 4600 if it's part of the power distribuition assembly).
pianotuna
Nomad III
Nomad III
Get a tiny cheap battery. For example:
https://www.costco.com/interstate-u1-lawn-%2526-garden-battery.product.100476412.html
Regards, Don
144Grayling
That may very well be true. But for now it serves our needs. This trailer is parked on our property to stay in during visits while we work on a permanent house here on the island. Itโ€™s a โ€œbridge strategyโ€ ( altho that bridge has gotten longer than hoped.) So as long as everything is working on 12.9 v (and it is) the motivation to put more money into it is pretty much zero. When we are done with it weโ€™ll probably just give it away and the new owners can decide what to do.
StirCrazy
Moderator
Moderator
144Grayling wrote:
The 12.9 was with the battery disconnected. (In fact the battery was at the NAPA shop miles away??) Looks like one vote for โ€œitโ€™s ok to run without a batteryโ€ and one vote for โ€œyou should put in a batteryโ€ Anyone else wanna break the tie?
And if I really do need a battery to protect the system should it be a deep cycle RV battery or a plain old car battery, knowing it will never be without shore power.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
wa8yxm
ScottG wrote:
but you don't need it to make the converter create clean power - at least not a converter from 2007.
Good that you added "From 2007" as some of the older (Magnetek) you did need a battery or what they called a "Battery simulator" (Hardening capacitor is another name for it.. ONE HIGH CAPACITY Condenser like a farad or two) to clean things up.
ScottG
144Grayling wrote:
Thanks for all the information. The battery is a 12 volt lead acid RV deep cycle battery from Les Schwab. No reason to think itโ€™s not what it says it is. As far as I know the only 12v functions in the trailer are lights, bathroom exhaust fan, radio and propane alarm. All those are fine on whatโ€™s coming out of the converter now: 12.9v No slide out, no hitch jack. Checking the panel it also has a few other 12v circuits that we donโ€™t use ( dont need the water pump since weโ€™re hooked up permanently, and the furnace, since we use electric heat instead of propane.) And it says the hood fan is 12v which I didnโ€™t know. So everything we need is working fine off the converter and shore power. I donโ€™t know why the converter was overcharging the battery to the point of boiling, but if it can go without a battery I really donโ€™t need to care about it. I suspect that I killed the battery by leaving it outside uncharged over a couple of winters and thatโ€™s my bad. But, again, if I donโ€™t need a battery in the system Iโ€™m ok. Still getting mixed opinions on that.
With that information, you don't need a battery. Your WFCO converter will take care of everything you describe.
ktmrfs
12V is needed for a propane/electric fridge (even on shore power) water heater (even on electric) usually for propane and sometimes CO detector
2011 Keystone Outback 295RE
ken56
Lead acid wet batteries get sulfated when left uncharged. The sulfur in the acid sticks to the lead plates and hardens on the plates if not knocked back off by charging...so yes, you killed the battery by leaving it in an uncharged state.
144Grayling
No surprise the battery is no good. Wouldnโ€™t hold a charge. Still unknown whether a bad controller overcharged it and killed it or I killed it by leaving it uncharged all winter and the controller just boiled it trying to charge it. For right now Iโ€™ll be running on shore power with no battery. Just for the next few days then shut the whole thing down for winter. Saw no point in buying a battery at this point. Thanks again for all the help.
ScottG
If your RV is sitting on a seasonal lot and never moves, you're fine without a battery. Having one will not change or improve anything. If you're towing or have slides that have to be moved in and out, you may need the battery for extra capacity but you don't need it to make the converter create clean power - at least not a converter from 2007.
pianotuna
Nomad III
Nomad III
Best practice is to have a battery.
Regards, Don
144Grayling
Unless the trailer is sitting on a seasonal site, you need a functioning battery to tow the trailer. A battery is needed for lights, turn signals, brake lights, and brakes.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
BruceMc
The more experienced amongst us might poo-poo this idea, but for your situation, perhaps a small sealed lead-acid (SLA) battery could act as that buffer.
Small SLAs are used for telecommunication & security equipment, and are readily available at your local stores for around $20-$30.
Search for "12V 7.2AH Sealed Lead Acid (SLA) rechargeable maintenance free battery".
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
JoeH
Why not just get a battery-- you didn't state size-- but something like a Group 24 that will run under $150 and install it. In the event of power outage, you will still have lights and if, by chance, your converter needs a battery, it will be happy too.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
