MrWizard
Nov 23, 2023Moderator
Problem Yes.
Because the converter is malfunctioning , the voltage us too high, running from the converter only is going damage the control boards for the fridge, air condition, heater, water heater , maybe burn out your water pump and vent fans, replace your converter, without a battery what will you do if shore power fails, everything will turn off , no heat, no water, no lights, even the fridge b will turn off
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
