dougrainer
Aug 26, 2016Nomad
KendallP wrote:
OK. That weird voltage situation appears to be solved. I had the 6300 series converter running with the bank unhooked. It was sending 7.5v to the board that way. Weird since that converter has a separate charging circuit, but we all know there are better converters.
Hooked it back up and I get about 13.5 at the board and about 13.1 at that humidity switch.
Doug,
Boards go too, right? What are the odds it's the humidity switch or something other than the board?
20 years ago I replaced dozens of the Humidity switches for corrosion failure causing the refer to not power up. IF the interior light comes ON in either position the switch is sending power to the board. IF the light comes ON, then odds are it is the board. Doug
