dano73
Apr 22, 2014Explorer
Old Style Propane Lines
OK, heres a question for u propane guys. I have an older trailer with the old style inside reverse thread tank fittings that u have to put on with a wrench. I had 1 valve replaced last year, cause it was leaking, when I tried to use the heater over the winter the other valve started leaking and it is still leaking now, I just turned it on to check. I looked inside the valve, it appears to be ok, but just wont seal right, and yes it is an opd. Should I replace the lines with the newer style plastic handles, I just looked at my bbq, they seem to seat differently, so I'm thinking newer is better right? what do u guys think, and where would I get them, any sources?
