AgateguyExplorerOct 27, 2016Onan 3600 lpHave a fault code reading 15 on an Onan LP 3600 and it says to drain the oil from the supply system. Any info on where to drain it?
3 RepliesReplies sorted by NewestMrWizardModeratorOct 30, 2016Oil in the supply systemThey are taking about oil in the l.p.This would mean disconnecting the l.p. Line, From the generator and cleaning/replacing the pressure/vapor regulatorIf that doesn't work, you will need to clean out the l.p. Tank and linesI would check with a propane distributor who services tanks etc..loggenrockExplorerOct 30, 2016I would suggest a call to Onan. They have seemed very receptive to my questions in the past. ST1492ModeratorOct 28, 2016Moved from Forum Technical Support
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
Related ContentHard Start - Onan 3600 LPOnan LP 3600 Generator - Hard Startonan 2500 lp generatorCummins Onan LP 25 won't start...Oil for onan 2500 lp
