howardwheeler
Jul 20, 2016Explorer
I did the flashing code check, and it was a 3 and secondarily a 15. It is an overload problem as we thought. I'm going to try the Supco Hard Start kit and see if we can get a little more out of the generator. Ultimately I'd like to be able to run two Mach 3 PS high efficiency ACs at the same time. They draw just a little over 10 amps running. I hope having one running already then starting the second won't shut down the generator. Running a hair dryer and microwave is mimicking the one AC running and trying to start a second. I really hope it works because going down the road with the one AC in hot weather doesn't cut it.
