RhigleyExplorerJun 29, 2021onan 4k genmy gen. will run without load for about 45 seconds then will hunt 2 times than run smooth again for a 45 more seconds again. When I put a load on it (1500 BTU AC) it will do the same but not as often....Show More
garyemunsonExplorer IIJun 29, 2021Try prying off the limiting cap on the altitude adjuster so you can open it a little more. If that cures it, the main jet needs to be cleaned.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
Related Contentonan 4k genOnan 4K gen?Onan 4K generatorOnan 5500 Gen in RVHelp! Onan 4K generator refuses to start and stay on
