Onan 4KYFA26100K GAS
TexasUltra
I may have committed the mortal sin of RV genset ownership. I got busy over the summer and didn’t exercise the toy hauler genset for a couple of months.
It tried to start once or twice and ran only for a second or two before dying.
Now it won’t start and smells of bad gas or maybe flooded with fuel.
I have it in storage and can’t get to the access door until I pull it out.
I always add stabil when I fill up and exercise it monthly. (until now)
An RV repair shop told me I need to replace the carburetor ($150.) because the neoprene plunger sticks or swells making repairs or rebuild a non-option.
Any thoughts or ideas before I start on this?
2015 Ford F-350 6.4 Power Stroke 4x4
2002 Excursion 7.3l PowerStroke (retired)
1991 Fleetwood Prowler 26 (SOLD)
2006 Weekend Warrior FS2300
2006 FLHTCUI UltraClassic Vivid Black
2000 FLSTF FatBoy Vivid Black
1995 EZ Go W/lift, mudders, and camo'd
3 REPLIES 3
64thunderbolt
ksg5000 wrote:
I suggest you use the forum search feature for the term "Seafoam" - popular product that many use to fix similar issue. Lots of info available.
Best thing you can do. You may need to remove the carb take it apart and soak it in seafoam for a few days then reassemble. I did this to one and it has been running fine for a year on my friends toyhauler.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
ksg5000
Kevin
the_bear_II
Mine will from time to time after sitting for months without being properly stored..... take several tries before it runs. There will be many starts and run for couple of seconds then dies. Eventually 5 or 6 tries it will stay running but may die after a minute...then restart and it continues to run.
You do need to wait after a couple of tries to prevent flooding.
