chast's avatar
chast
Feb 05, 2019
Onan backfire?
Onan 2800 is hard to start. It was serviced about 10 hours ago and runs well once it has started. I exercise it once a month, but it is hard to get going. Once it has been started, it is easy to start again. It requires too much cranking and every once in a while it will backfire. Previous owner told me to hold down the start switch in the off position for 30 seconds to prime it, but this doesn’t seem to help and the owners manual doesn’t say anything about priming. Unit is installed in a ‘97 Pleasureway. Why is this thing so hard to start??
  • You will get fantastic tech support over on the Smokstak forum:
    https://www.smokstak.com/forum/forumdisplay.php?f=1
    My Onan 4BGE has no primer ability. It is hard to start after it has been sitting a month. I suspect the carb needs to be re-filled with fuel and so it takes 2-3 cranking attempts of 10 seconds each to get it to fire off and run.
  • For the Onan techs:
    Model 28KV F A 26100E
    Serial number E963538742
  • An onan technician will need the exact model and serial number or some will not even reply.
  • When I used to put Stabil into my gas tank and run the generator a while to circulate it, it would almost always backfire when attempting to start it again at a later date. After the initial start which would take awhile, the generator would run ok. I don't use Stabil anymore besides my new rv has a propane generator.
  • Take some canned starting fluid (ether) and spray it into the carb when cold just prior to cranking/starting. If it starts/fires easily and then runs fine, your choke needs adjustment. If not post back.
    Chum lee
  • Backfire through the exhaust is usually too rich. Use less choke.
    Backfire through the carburetor is usually too lean. More choke.
    I suspect the carburetor or fuel system in general needs work. I am not an Onan expert.
