- Remember, do not over fill. That will on some also shut it down.
- rwj146ExplorerI haven't had a chance to check the oil, but I filled the fuel tank before I parked the Van. Probably oil, at least I hope it's something simple...And cheap.
- horizon36ExplorerHow much fuel in your gas tank. If it's low and you accelerate the pick up tube for the genset could be sucking air for a moment and possibly stall the generator.
- MNtundraRetNavigatorI would also check the connectors to the control-board, and look for a loose ground wire. A bad connection can vibrate while moving and kill power to the generator.
- rwj146ExplorerOnan Microlite 2800.. I will check the oil again. thanks.
- BobboExplorer III agree. The oil level is marginal and when you move the van, the oil sloshes away from the oil sensor and kills the generator.
Check your oil level. - Oil level switch if equipped.
Exact model of Onan?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
