My Onan 7.5kw diesel generator starts and runs five minutes (load or no load) and dies with a error code 24 (Temp. sender fault). I can restart it immediately and it will again run five minutes and die. Output on each leg is 123V while running. Is there an access panel or opening where I can visually verify that the belt is OK? Where is the temp. sender and how do I access it?
Bill Simonds
'99 Winnebago Ultimate Freedom
330HP "Yellow" motor
'94 K5 Blazer 4X4 toad
