roadrat57's avatar
roadrat57
Onan Gen Starts then Shuts Down
FYI: Did extensive reading/viewing about this problem.(I have an Onan 5500 Marques Gold 2008.) Replacing fuel pump, filter and oil sensor did not resolve the problem but what did work was running 2 to 1 ratio of gas to Sea Foam through gen. Performed starting procedure by disconnecting fuel line from fuel filter and attaching 1/4" gas line from filter to mason jar with sea foam mixture. Gen started for 10-20 seconds then shut down several times but I managed to get the mixture into the carb. Allow 1-2 hours for mixture to sit in carb then restart. Ran like a champ with or without a load.
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to "posting" issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
  • Next time try the Seafoam first. :)
    It cured a surging problem with my Onan 5000.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
