awesomeman's avatar
awesomeman
New Onan 4000 wont start
Hi. I’ve got a Winnebago 2018. Our generator has about 30 hours on it and was last used about 60 days ago. Everything worked fine. I went to crank up the generator today and it cranks, starts, and then immediately shuts off. After that it only cranks but will not start. It also didn’t sound like it stalled out. Sounded like it was shut off. Here’s what I e tried. It’s a Cummins Onan 4000
1. Oil was recently changed before last use and oil level is accurate
2. Primed the lines for 30 seconds as mentioned in manual
3. Tested fuel lines. Fuel pump is working and pumping fuel just fine.
What are the common early failure parts on these generators. It’s so weird since it is newer. Nothing should be failing at this point but these things happen. I know on my last generator the oil pressure sensors were notorious.
Any help is appreciated as I’ve literaly owned the rv just over a year and the warranty is out. Lol.
Thanks
